A strange cooling problem
17 Dec 2004
I have a fan on the side of my case blowing onto my graphic cards
I upgraded from a Akasa Amber Ultra Quiet 120mm Fan
- Rated speed: 1400 RPM
- Sound: 18.0 dB(A)
- Air flow: 44.8 CFM
To a 120mm Sharkoon 2000 "Golf Ball" Quiet Case Fan
- Approx Fan Speed: 2000 rpm
- Fan Airflow: 76.3 cfm
- Sound Level: 36.1 dB
The golf fan dosent cool the graphics cards down as much as Akase fan :confused: :confused: and the golf fan is cooling 1 card more then the other too :confused: :confused:
Someone please explain, cos I would have thought my graphic cards would have been cooler with the golf fan? :confused:
perhaps its blowing too hard and robbing the fans on the graphics cards of air. like trying to breathe when you stick your head out of a car window @ 50mph.
James has to correct IDEA IMO,
I removed the side fan off my Thermaltake Tsunami Dream and blanked it off, it disrupts the airflow.
Getting a couple of 120MM High CFM Fans in the case will help more than the side fan..
speedy2004 said:
So basically if I want to use it, I will need to get a fan control
Well, its only a theory but its perfectly plausible:) try 5volting the fan and if the temps imporve, you know its an airflow issue:)
