A system which should implemented into Live
Permabanned
19 Dec 2005
The ability to 'queue' downloads, so that once one d/l has finished, it will start the next download.
Even better...the ability to dowload more than one file at the same time...
think its being worked on, i think they lied about the last patch as i dont think it was the one that was suppose to fix anything like they said it would. People still got same prpblems, instead it was a way of getting people to update so they cant use those kiosk discs. I think they intend on fixing that so u can do something else whilst downloading when they do release the proper update.
I'm looking forward to the background downloading/queued downloading too! Roll on the next patch!
