- 9 May 2009
hi all i just bought an icy box this one
http://www.raidsonic.de/en/pages/products/external_cases.php?we_objectID=5453
and to be honest its not to good why you ask, 2 problems
P1 this drice does not work with 2 of my sata 1 maxtor drives it will not even try to power them up and i know its not the drives as i have tried them on my motherboards sata plugs. (works with my Sata 2 samsung f3 perfectly byt teh way so teh enclosure works)
P2 i am using eSATA from the enclosure and when windows is booted i plug the drive in as i have it selected as hot plug swap but the transfers are 30mb a sec which is about usb 2 speed, If i turn the drive on first then the computer the drive then will transfer at 100mb as sec but why does it not do this when i use hot plug ?
these 2 problems are getting on my wick and wanted to know if there is a better SATA External Enclosure that supports esata usb2 or 3 that lests you swap the drives in the enclosure as i am going to be sending this back, I thought icy box where the best ?
any help or suggestions
thanks
thanks
