BenQ EW2440L 24" Widescreen Flicker Free LED Monitor - Black @ £149.99 inc VAT
With a sophisticated all-around slim design, the latest MHL connection and BenQ’s state-of-the-art visual optimization technologies, the all-new EW40 Series take your multimedia entertainment to a new level of fun and ease. Enjoy a cinema-class picture in the comfort of your own personal space for home entertainment or office work
Key Features
- Go Big With Your Smartphone
- Transform mobile entertainment with MHL connection
- Cinema Mode fine-tunes video contents to perfection
- Upscale Every Viewing Experience with Super Resolution
- Distraction-free Viewing with Smart Focus
Aspect Ratio: 16:9
Resolution (max.): 1920 x 1080
Pixel Pitch (mm): 0.276
Brightness ( typ.): 250 cd/m²
Native Contrast ( typ. ): 3000:1
DCR (Dynamic Contrast Ratio) (typ.): 20M:1
Panel Type: VA
Viewing Angle (L/R;U/D) (CR>=10): 178°/178°
Response Time(Tr+Tf) typ.: 12ms, 4ms (GTG)
Display Colors: 16.7million
Color Gamut: 72% NTSC
Input Connector: D-Sub/ HDMI/ HDMI(MHL)
Power Supply: (90~264 AC) Adapter
Dimensions(HxWxD mm): 421.6 x 545.66 x 191.32
Net Weight (kg): 3.74 kg
Was [OLDPRICE] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
BenQ GL2250HM 21.5" Widescreen LED Monitor - Black @ £99.95 inc VAT
Enjoyment for Your Everyday Home and Work Life
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2250HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, speakers, response time of 2ms and DVI and HDMI connector, this 21.5"W 16:9 LED monitor delivers you the audiovisual enjoyment.
Key Features
- 12,000,000:1 contrast ratio
- Audiovisual Enjoyment with Speakers
- HDMI Multimedia Interface
- Superior Response Time
- Senseye® Human Vision Technology
- Screen Size: 21.5”
- Aspect Ratio: 16:9
- Resolution (max.): 1920 x 1080
- Pixel Pitch (mm): 0.248
- Brightness ( typ.): 250 cd/m²
- Native Contrast ( typ. ): 1000:1
- DCR (Dynamic Contrast Ratio) (typ.): 12M:1
- Panel Type: TN
- Viewing Angle (L/R;U/D) (CR>=10): 170°/160°
- Response Time(Tr+Tf) typ: 5ms, 2ms (GTG)
- Display Colors: 16.7million
- Color Gamut: 72% NTSC
- Input Connector: D-Sub/ DVI-D/ HDMI
- Power Supply (90~264 AC): Built-in
- Power Consumption (On mode): 30W (max)
- Dimensions(HxWxD mm): 399.9 x 524.69 x 173.9
- Net Weight (kg): 3.8
- Gross Weight (kg): 5.4
Only £99.95 inc VAT.
ORDER NOW
BenQ DL2215 21.5" Widescreen LED Monitor - Black @ £79.99 inc VAT
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ DL2215 LED monitor is the perfect choice for you in style! Featuring aspect ratio 16:9 and 100% dot-to-dot image quality, this 21.5"W LED monitor delivers every image detail with the best viewing quality.
- Screen Size: 21.5"W
- Resolution (max.): 1920x1080
- Pixel Pitch (mm) 0.248
- Brightness ( typ.) 200 cd/m²
- Native Contrast ( typ. ) 600:1
- Panel Type TN
- Viewing Angle (L/R;U/D) (CR>=10) 90°/65°
- Response Time(Tr+Tf) typ. 5ms
- Display Colors 16.7million
- Color Gamut 72% NTSC
- Input Connector D-Sub/ DVI
- Power Supply (90~264 AC) Built-in
- Power Consumption (On mode) 20.7W
- Dimensions(HxWxD mm) 369 x 515 x 178
- Net Weight (kg) 2.8kg
- Gross Weight (kg) 3.9kg
Only £79.99 inc VAT.
ORDER NOW
Key Features
Aspect Ratio: 16:9
Panel Type: VA
ORDER NOW
Key Features
- Panel Type: TN
ORDER NOW
- Panel Type TN
ORDER NOW
