** A TRULY SAVAGE DEAL!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Kingston / HyperX have given us a Savage deal:
Kingston HyperX Savage 240GB SSD 2.5" SATA 6Gbps Solid State Drive (SHSS37A/240GB) @ £64.99 inc VAT
Powerful performance, unparalleled design.
HyperX® Savage solid-state drive off ers extreme performance for the extreme performer. The fastest HyperX SATA-based SSD, it’s powered by a quad-core, 8-channel Phison S10 controller that delivers incredible speeds of up to 560MB/s read and 530MB/s write, with read/write IOPS up to 100k/89k. The result is ultra-responsive multitasking and an overall faster system that maintains performance even as the drive fi lls up.
With its low profi le and slim, 7mm form factor, HyperX Savage SSD fi ts in most notebooks, desktops and HTPC builds. Its unique look, with highquality red steel and aluminium casing and diamond-cut design, helps you stand out in the crowd and complements the latest PC hardware.
It’s available in a bundle kit that includes everything you need to install Savage in your existing system, including a USB 3.0 enclosure to transfer data from 2.5" hard drives; a 2.5"–3.5" adapter to mount in a desktop environment; SATA data cable; multi-bit screwdriver and Acronis® data migration software. HyperX Savage SSD is 100 per cent factory tested and backed by a three-year warranty, free technical support and legendary reliability.
Features:
- Powered by a Phison controller with SATA Rev 3.0 (6Gb/s) performance
- Speeds of up to 560MB/s read and 530MB/s write
Specifications:
- Form Factor: 2.5"
- Interface: SATA Rev. 3.0 (6Gbps)
- Capacity: 240GB
- Controller: Phison PS3110-S10
- Compressible Data Transfer (ATTO): 560MB/s Read - 530MB/s Write
- Incompressible data transfer (AS-SSD and CrystalDiskMark): 520MB/s Read - 510Mb/s Write
- IOMETER maximum randon 4K read/write:100,000 / 89,000 IOPS
- Random 4K read/write: 93,000 / 89,000 IOPS
- Life expectancy: 1 million hours MTBF
- Warranty: 3-Years warranty with free technical support
Was [£85.99] Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
A damn good SSD from Hyper X and a savage price indeed. :)
** Post deleted as spam **
Yes of course, its a 2.5" SATA device, so no different to any other SSD. :)
Bargain! I paid 80 something for mine. I need another, but this price wont last knowing my luck.
Have to say they are cool looking drives. Literally just bought a cheap 120 Kingston for my rig too....gutted
We use the hyper X drives in our retail POS systems at work. Kingston drives are bullet proof from my experience so far
Hi,
Could you clarify if this deal includes the 2-5"-3.5" mount & other bits as stated in the op. Or if it's simply the SSD & nothing else?
I ask because you are also selling SHSS3B7A/240GB @ £89.99 which appears to be the exact same product?
Cheers:)
Hi,
Cheers:)
I would like to know this also.
