3 Nov 2019 at 17:30 #1 Edward78 Edward78 Soldato Joined 19 Oct 2002 Posts 5,780 Is there, my moniroe has buttons, but theu are a bit odd.I have a app called Brightness controller, but it doesn'r seem to work.
3 Nov 2019 at 20:40 #2 pete910 pete910 Soldato Joined 3 Oct 2013 Posts 3,882 What DE are you using? If you're still on the specs in you sig IIRC Nvidia has a control panel that can adjust it KDE has colour/Gamma under system settings
4 Nov 2019 at 19:19 #4 pete910 pete910 Soldato Joined 3 Oct 2013 Posts 3,882 Edward78 said: Anything in Mate? Click to expand... Not sure , hardly used it to be honest. Found it lacking when I give it a go.
