Hi all.
Recently moved over to X79 and started to overclock with my 3820 and 16GB (4x4GB) 1600mhz vengeance memory on a UD7.
From what I have gathered once I start playing with the BCLK I have to start adjusting the memory to suit.
Firstly I have a couple of questions about my current memory, I don't know a great deal about memory but I figure I will have to learn at some point. The default XMP timings are 9-9-9-24-2T, the profile stated tRFC is 48. When I switch to XMP on the motherboard the timings switch to 9-9-11-24-1T with a tRFC of 138 - do these sound drastically wrong? Also CPUZ states the quad speed is 800mhz, surely this should be 400mhz in quad channel?
Also while playing with the BCLK I ended up at 1666mhz, gave it a little nudge on voltage to 1.55v from 1.5v and windows insta-crashes even with no CPU OC.
SO am I doing something wrong or missed a setting to help keep things stable?
Starting to think life would be easier with some of the samsung green memory as I shouldn't need much of a voltage nudge to apply light clocks to the memory.
Thanks in advance
Edit: Some info today would be brilliant as the samsung green is down to £90 for 16GB today only!
Thanks in advance
