A word of warning to X-Fi Mode CHanger users
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Those of you using it, keep a lookout for today it appears to have borked my xfi drivers! I had to reinstall the driverset fresh to solve the problem.
Situation
After exiting a heavy round of Rainbow Six Vegas the X-Fi Mode Changer Utility would normally revert the mode to Entertainment mode but this time it didn't and upon exiting I saw a BSOD and the driver that caused it was a CTSxxx.sys file which is one of the XFI drivers.
I rebooted and whenever I tried to enter Game Mode I would get a windows popup telling me in order for changes to take effect I would have to restart windows...I clicked "Yes" to reboot and nothing happened.. during shutdown windows shuts down runing services one by one and it looked like Since Audio Console could not load Game Mode properly Windows was hanging on the sound driver to finish its action before shutting down (which it did about 10 mins later)
Anyway I did a search on Creative forums and another guy also using xfi mode changer had the exact same problem. he too solved it with a reinstall of the xfi drivers!.
Now I know mode changer works well but with some games it seems to try and change mode too late or too early hence corrupting the xfi driver. Perhaps this is why Creative did not put an auto mode switcher into the audio console? It makes sense now.
I have now stopped using mode changer and have bound creative audio console to a programmable key on my logitech keyboard for quick access when modes need changing.
Guess manual is the safest way from here on :eek:
/my two pence
Its only happened if my system is not fully stable because of still messing with overclocking.
Also all you have todo is goto Control Panel/ Audio Console=Restore Defaults tab & hit Restore Defaults & it will all be working again like before.
It has not happened for quite some time now as i have not been pushing the overclocks lately.
Final8y said:
That does not meen that your system is stable :)
heh my system is stable, I've noticed numerous odd things whilst using the XFMC utility and my system never crashes in anything otherwise!
The last time I had a crash was when I installed a set of nvidia BETA drivers and during a sessions of CSS I got a nv4disp.dll bsod. Reinstalled newer drivers and all was fine once more.
Trust me on this one, my system is stable and *** only things that crash are bad software or drivers! :)
tommy_knockers said:
you can blame creative for that.
Maybe im deaf before im 18 but I brought a
XFI- extreme music
and Creative G500
to upgrade from unboard sound and my schools £2.50 2.0 speakers
:confused:
It's not creatives fault if a non creative utility causes the crash :p
