A09 HTPC Computer Case Mini ITX Gaming PC Chassis Desktop Chassis USB2.0 Computer Case Home Computer Case Black?
Manufacturers website? Even plain ole Google shows me dimensions but it’s listed on a competitor website so can’t link.
I found a case which I thought was the same case on a major Chinese etailer site:
Case Size
187x228x89mm
But the name for that case is slightly different.
But can find an identical looking case, with again a slightly different name on the large rainforest site with the same dimensions listed
  • Product Dimensions ‏ : ‎ 18.8 x 8.89 x 22.86 cm; 1.18 Kilograms
You know, I just thought why am I thinking this much? If I could just do a 5" wide 8" Deep & 10" tall havee the power supply sucjk from the outside & have the expansion slots on the other side. I could jusy sit it flat, it be nice & small. Like a Silverstone Sugo with the PSU sideways on the side of the case. Not sure why no one is already making cases like that, I nean so simple.
I don't really understand you and cases. You just come in every so often to ask information on manufacturer websites/marketplace websites, then disappear for a while. :D
From all the questions you ask about cases, I already know you don't want the A09 as a case.
For people who're maybe interested, but unsure of quality for the low price they are. They're alright. I have the A10, and it's great for what it is.
Sorry about all that, just wanted a small case that will fit a 2 fan GPU. Plus, have the psu in a normal place, front PSUs are odd. though, Small like a Bia bottle, not sg04. https://www.drinkbai.com/
Can you give me the measurements of the A0(? The esite has them, butg not sure if they are right? I think they are for the box. Plus a youtube video make it look way smaller than the esite says.
303mm x 92mm x 260mm
This is what I got, for the A10.
A normal MATX B450M Plus Gaming is a tight fit. Needing the USB ports PCB to be removed when installing the board, and replaced after it's in. It's not a big case, for a MATX.
Taobao has 187mm x 228mm x 89mm for the A09. Great for a no GPU build.
Man, if one was 4.1 inches on the lowest measurement, they could be a sandwich style just sit a PSU besside the MB & GPU. Or 5 & reversed put Reg. Height GPUs in. If I could getthe encloser with out the trey, I could get a sandwitch style trat & a PSU backplate to make a frankencase.
I don't understand at all. You know it's not this kind of case, and it never could be.
I don't get get the extreme need for a sandwich style case. It's been years now.
