A10-5800k temp monitoring & oc'ing
5 Feb 2009
N. Ireland
just built a htpc based round the above apu, but hwmonitor and coretemp are giving me weird temp results, jumping all over the place form ~40ºc to ~80ºc
initially thought my cooler wasn't on right but reinstalled it and got the same results, fans aren't ramping up or down on the cooler either
checked in bios and it's reporting a steady 35ºc
now i'm sure I read somewhere, possibly on here, that the above temp monitors aren't particularly good at monitoring trinity chips, anyone know of any that are?
also in the bios everything seems to be locked off and I can't seem to tweak any of the settings, everything from ram voltages and settings to apu voltages and settings seems to be blocked off.
first time using these fandangled uefi bios' so i'm stumped!!
this is the motherboard i'm using if it helps
https://www.overclockers.co.uk/showproduct.php?prodid=MB-427-GI
