A3 frame
28 Dec 2003
Not sure where this belongs but figured some in here may know.
I'm after some A3 picture frames. Must be glass fronted with a thin black bezel.
I'm really struggling here, the only ones I can find have bezels which are too thick for my taste. Anyone have any ideas?
define "thin"?
A quick google suggest companies describe A3 frames with 20mm surrounds as "thin" but I assume you are after something smaller???
You could go frameless and get clip frames?
Find a local framing shop and get them done there. Best way most of the time IMO. Much better quality as well.
The stuff I had had done by a local shop is a huge step up from anything I've had from online retailers or off the shelf purchases. Wasn't cheap but then it has made the pictures being displayed look much better!
