20 Sep 2013 at 22:11 #1 doggles doggles Associate Joined 17 Jul 2008 Posts 819 Location Potatoe hi bit of a problem with my A3 for some reason my indicators intermittently indicate in the wrong direction I.e select left & right flashes etc anyone had this & know how to solve it?
21 Sep 2013 at 02:14 #2 Scania Scania Caporegime Joined 25 Nov 2004 Posts 26,045 Location On the road.... Had a faulty relay cause this before in a Scania HGV... My 0.02
21 Sep 2013 at 03:01 #3 MissChief MissChief Caporegime Joined 17 Jul 2010 Posts 27,127 You haven't had the dash off or the 'wheel off for any reason? if not, faulty relay as Scania has said.
21 Sep 2013 at 08:50 #4 Biohazard Biohazard Permabanned Joined 29 Aug 2003 Posts 31,330 That's quite an unfortunate fault it's produced. I would solve it by driving in reverse when it happens.
21 Sep 2013 at 09:49 #5 doggles doggles Associate OP Joined 17 Jul 2008 Posts 819 Location Potatoe Biohazard said: That's quite an unfortunate fault it's produced. I would solve it by driving in reverse when it happens. Click to expand... lol! yes it is a bit irratating when going down the motorway it's busy and I go the opposite direction to what the car says it's going to do & thanks scania will look into that. no dash off or wheels
22 Sep 2013 at 09:54 #6 Tomcat825 Tomcat825 Associate Joined 23 Sep 2010 Posts 1,331 Location Bucks Christ, that's actually a really dangerous fault on he motorway hopefully you can get it sorted ASAP
22 Sep 2013 at 10:46 #7 brooksesi brooksesi Associate Joined 11 Mar 2010 Posts 17 Indicator relay, which I think is the hazard button on A3's, would be my punt
22 Sep 2013 at 11:38 #8 tom_nieto tom_nieto Soldato Joined 18 Oct 2002 Posts 13,035 Location Birmingham Are you female? This may be the problem here...
22 Sep 2013 at 12:00 #9 doggles doggles Associate OP Joined 17 Jul 2008 Posts 819 Location Potatoe tom_nieto said: Are you female? This may be the problem here... Click to expand... ******
22 Sep 2013 at 13:53 #10 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,385 Location Spalding, Lincs I think most A3's have this fault, it must be the reason why the majority of owners give up using the indicators completely.
