A4 Colour Printer
10 Apr 2015
Hungerford, UK, Earth
Hi any recommendations for an A4 colour printer for office use for 2 to 3 people. currently using an old HP laser, that keeps having issues but i dont know how cost effective these still are compare to inkjets. Doesnt need scanner but most seem to have this regardless. must have network card. Hp Officejet pro dont seem to badly priced then after that it seems your jumping back into laser territory
Been using an Epson eco tank 2550 for years in the home, no problems. Easy to maintain and use ink tanks instead of cartridges.
Laser printer quality is superior for work-type documents such as text. What are you printing? What's it used for?
I'm thinking it will now be a colour laser either. Printing building specs with lots of photos, probably go HP if i can find some suitable compatible toners
If you going to do Lots of photos and letters then an Inktank is your best bet these days.
The ink tank inkjet printers are the most economical for your situation.
I bought an Epson EcoTank ET-3750 a couple of years ago and I still have not run out of ink yet, and when it does, the ink tanks are reasonably priced, unlike the old days when ink cartridges cost a fortune.
That model is no longer available I think the newer version is the EcoTank ET-4800
