A64 Controlling fan speed?
3 May 2003
Stupid question, but is my Opty controlling the fan speed? The CPU fan tends to speed up to full whack every 10 so or minutes for a shortish (5+ mins) while.
Is this normal and how can I disable it?
Your bios has setting for fan speed adjustment depending upon what temperature you have specified. ie. Fan on full if CPU temp - 50 degrees. Check your bios screens.
