A64 MaxTemp
Wedge said:
Hi Peeps
What do you make of this...
http://www.btinternet.com/~wedge007/ocuk/3700.jpg
Firstly i bought a 'san degio` CPU from OcUK but it says `toredo`
second what does all the figures mean?
third is it any good? :cool:
Running at stock atm, just installed it .......37oc idle, not really put it under load yet.
thx
Youve got a failed dual core chip there, with once core disabled :)
EDIT : There are also 4 pages about it here :) >>http://forums.overclockers.co.uk/showthread.php?t=17568372
MaxtCase temp is what the processor will be stable upto at stock speeds.
Anything over that and it *may* become erratic
Hey Tom
Thx for that, do you know if mines a goodun?
welshtom said:
its a failed dual core.
61 is a pretty good value yea.
i'd hope for 2.7-2.8 tbh
Ow not to bad, its running stock atm.
must go and re-learn clocking, just going to give it a little push, running it on a Asus Premium with a sythe Ninja 1gig of Geil value PC3200 ram got it up to 43o under load (1 hour of QIII Arena)
advice welcome ;)
