A64 X2, Best 2GB DC Kit? *Please help!*
19 Dec 2003
UK
Ello!
Im in a dilemma! I currently have 2 x 1GB Crucial Ballistix Tracer DDR500 Ram chips, but they dont work properly in my MSI K8N NEO4, they are not matched, thats possibly the problem, but anyway I want to change them.
I was under the impression I only needed PC3200 DDR400 Ram for my system? Is that correct? As the bus speed runs @ 200mhz for the CPU so I dont need ram that runs above it?
What is the best 2x1GB DC kit I can get? I was looking at the Corsair or even the OCZ Platinum or Gold PC3200. Even Geil value!
I wont really be overclocking it, well maybe not for now ( :p ) I just want the tightest latencies at standard speeds that work best with the A64 4400+ X2.
Many thanks for advice in advance! :)
Sean
