Everytime that i boot my pc up after it has been off for a few hours i am getting a warning message about the fan speed. Its saying that the fan speed has fallen below a certain speed and that i should press F1 to continue.
I have looked in the bios and have set the minimum speed warning to 800 rpm but the message still appears next time. There dont seem to be any problems when the pc is running, and it boots fine after the initial boot up.
I have speedfan installed and this reports that all my temps are running at about 45 C. Just looking at the heatsink and fan and they seem to be ok (fan seems to be spinning properly). I have also put some new thermal paste on the chip.
I have just updated the BIOS so maybe this will help, but i am not very confident. Problem is i cant tell if its fixed it until i switch it on tomorrow!
I have had a read around the net and it seems that a few people have similar problems with the same motherboard, but i cant find any definitive answers.
Has any one had this or a similar problem and managed to fix it or have any advice?
AMD 939 3200
A8N-E
1 Gb Ram
Cheers
AMD 939 3200
A8N-E
1 Gb Ram
Cheers
