A8n-SLI and LAN problems still :(
19 Oct 2002
Yeovil
i recently put together this motherboard and are having problems using the onboard marvel Lan...its connected to a 1800HG router,from BT..via a 3m cat 6e cable.....on my old system i was using the USB drivers for the router,which worked fine ,and i also have 2 other pc's connected to the router via wireless connections...
The problem is every now and again i lose my internet connection,only for a split second....i have run a ping test to the router and is does have a 'hardware problem' appear on the test which gives me 1-2% packet loss during a 15-30min ping test...now i could put up with it if im just browsing the net,but i play online games,24/7 and this conection loss problem is making it the online games unplayable.....ive used the drivers for the marvel lan which came on the motherboard cd....
My other question is how do i use the other Nvidia lan socket,i have enabled it in the bios,and plugged cat 6e cable into it,the lights flash on the back of the MB on the lan socket but i dont get an internet connection..could someone please explain what i need to do to use this nvidia nforce 4 lan it may sort out my connection problem.
I hope you can help
thanks in addvance
shaun
