- 27 Oct 2005
Guys
I’ve just upgraded my mobo from an Asus A8N-SLI Premium to an A8N32-SLI, I’ve also decided to swap the stock CPU cooler for an Asetek VapoChill Extreme Performance item.
My spec is as follows;
Coolermaster Case with rear fan
Enermax Noisetaker 470W PSU
Asus A8N32-SLI Deluxe (Gamer) Motherboard
AMD FX-57 CPU
Asetek VapoChill Extreme Performance CPU Cooler
Crucial Ballistix 4 x 512MB (DDR500)
Raptor 74GB SATA-II HD
XFX Geforce 7800GTX 512MB
Using Asus Probe II utility, at times the CPU can easily reach 60 degrees, this seems hot considering the CPU cooler I am using, are any other A8N32-SLI users getting these temps at load? The motherboard temps tend to stick to around 45-50 degrees also.
I have also noticed that the in-built RealTek sound device has crackly sound?
Thanks
AMD FX-57 CPU
Thanks
, but the thing was noisy and didn't do a very good job even when fitted correctly. I've tried a few hsf's; Thermaltake K8, Zalman 7000, Arctic Cooling Freezer 64, Asetek Micro Chill Extreme and a Zalman 9500, overall the 9500 easily get's my vote. It cools really well, is easy to fit and doesn't weigh so much that you're paranoid about it pulling the CPU out of it's socket. I've heard good things about the Big Typhoon's performance although it's really heavy, 815g?
