A8V Front Audio
18 Oct 2002
I have got a Asus A8V Mobo and I have recently purchased a new ATX case,
with front Audio Connectors/USB connectors, and want to set up the front
ones so I can have my back audio for my speakers and the front ones for my
headset, because at the moment have too keep on changing wires all the time.
I have read through the manual about the Audio front pins, but they letters
on the manual do not match the ones on the pins. Have not got the case by me
now but they are as follows ( L, R, Mic, G) which is left, right, mic and
ground but doe's not match up to the mobo manual.
Also the USB's as well, they have got VCC+, PORt-, PORt+, cant remember the
other one but just need to know where they go any help would be appreciated!
L = Line out_L
R = Line out_R
G = AGND
USB only uses 4 wires each connection. +5v -data +data ground
VCC = USB+5V
PORt- = USB_P#-
PORt+ = USB_P#+
? = GND
If you have more than one, follow the # sequence.
