AA problems ar source games
12 Jun 2007
Ireland
When i installed vista 64 bit everything was fine till i noticed when i play tf or cs:s i go to advance video options set aa on 8 or 4 does not really matters i apply settings and then when i switch the game of and i comeback to it its back to 0 again. is it something wrong with nvidia drivers as this never happened before when i used xp ?
So basically when every time i want to play game i have to go in options set aa witch is really annoying
Ty for help
169.25 i think
mh i think i have to fiddle around with my config or something im not sure never had to do that before. the same happens on sound settings i put 5.1 sound and when i want to play the game again its on 2 speakers
just checked lounch options of tf2 and css and it showed the command +mat_antialias "0" never had it before when using xp what does it do ? maybe its the problem ?
Source games have a problem with AA being turned on in the video card cp. Make sure you turn it off outside of game and on inside of game.
