It's not often I feel the need to recommend a product but these are amazing.
The Achari one in particular is like nothing else you'll try from a premade Indian curry in a jar. It contains Lime Pickle which really gives it a unique taste, quite hot with all sorts of subtle flavours going on - like a Madras but with greater depth. I had chicken with it first time around which was nice, but second time was best with lamb so it holds up to the flavours, beef would be good too. I usually add all sorts to the other brands, on this stuff just a few mild green chillies and chopper coriander work a treat.
Highly recommended from the usual Pataks and Sharwoods bog standard varieties
Anyone tried them?
Only seen them in Asda so far.
Anyone tried them?
