AB9 Pro + FF boot code ?
12 Jun 2003
Just noticed this since i updated the bios.
When i boot up it displays FF which in the manual says Boot Attempt (INT 19h).
I have no idea what this means
Basically something is stopping it from booting...what bios are you using and have you checked the hardware attached to it? Judging from forum posts I've seen elsewhere it could be a memory issue.
tang0 said:
Everything boots fine though i don't get it
You gave the impression it didnt boot at all..sorry if I misunderstood.
Just ignore the message then? Revert back to previous bios if possible?
FF Boot attempt (INT 19h) Power on -> Stop at FF Normal Operation blank
.. from the Abit website, looks like FF means its all good
just me being paranoid :P
FF is normal operation, thats what mine is sat at now. (different board, same diag codes though)
The older bios might of defaulted at being set to 'off' and the new set the diag code to 'on'.
