AB9 Pro Queries.
1 Mar 2007
Bristol, UK
Hi, I Have Just Bought The AB9 Pro, £47 from the sale section, new not used nor is it oem.
just wanted to get some confirmations from current or previous users of this board.
Is there still memory problems?
i have 2GB Geil ULL DDR2-800 & E6300
& The Last thread about these issues it seemed like all was well.
so i would just like confirmation on the issues or should i return the board?
was looking at P35's but finally gave in and bought a cheaper 1 for now :(
Full Spec To Be Built Once Arrived:
E6300
AB9 Pro
7800GTX
2GB Geil ULL
Tuniq Tower 120 LED Version.
was fixed many bios`s ago but i suggest you set the timings yourself instead of letting it auto detect the speed.
Your spec is what i had setup when i first bought mine btw been a flawless mobo since then :)
