Abba front lift arm
2 May 2004
I'm looking to get the Abba front lift arm for my Abba Superbike stand.
It comes with a "Triumph V1 Hub Spindle" for compatibility with my bike.
Does anyone know if this is something I'd have to attach permanently, or can it be taken on & off?
Thanks
I think it can be taken on and off,its for the strap to attach to to stop the front end nose diving when its on the stand
youll need that spindle because you have a single sided swingarm
It's literally just a pin that you push into the hole in the middle of the hub so you have somewhere to attach the strap to. It's not permanent.
Removable!
It works very well, just lean on back of bike to lift front then pull ratchet strap tight. I had mine in the air for 5 days without a front wheel on.
Cheers, sounds just like the attachments for the normal left then, one sits over a bolt and the other presses into a hole in a bolt.
