abit ax78 not booting up
24 Jan 2004
I got new pci-e HD3870 graphic card and tha bit ax78 mobo as well.
Basically i have akasa powermax 1000w power supply.
The graphic car does not seem to boot up as the fan is not spinnnign on it.
i have hooked up the 20 pin in the place where the 24/20pin should be. I also plugged the 4 pin into where the 8 pin should be as well as i don't have an 8 pin.
Now it starts everything lights etc but just a black screen.
any ideas.
thats the one. those connectors they have now are new as they are detachable from the supply. yes the cable is hooked uo to the g-card. I also noticed the hdd and dvd drive do not power up at all yet the case fan and cpu fan do. I hooked up a 350w psu from my other psu wich has a 4 pin and a 20 pin plus I hooked up the graphics card as well and same symtoms no hdd power up or dvd as well??!! could it be the mobo doing that.
