- 20 Feb 2003
Hi - I'm about to build an HTPC based on this board & have a couple of questions :
Thanks for any advice you can give!
- The manual says that it dosen't support x4 device width RAM, so should I go for "CAS 5-5-5-15" or "CAS 3-3-3-12" RAM? Performance isn't so much of an issue as I won't be overclocking. Value is my priority here.
- As for a cooler I want to keep the noise down as much as possible, does anyone know if the Zalman CNPS7700 will fit OK? The case will be the Antec Fusion so I guess a fanless Scythe is out of the question as it will be too tall.
