Abit Fatal1ty FP-IN9 or similar with 4 IDE ?
19 Oct 2002
Help !
Thinking of this as a basic dual core (cheapo model)
some comments on great or rubbish !
i would run at normal spec - but a "slow" dual core if that makes sense
not trying to push the envelope
but will be on 24/7 sometimes - downloading
any comments welcome and/or other models - seen the asus sli mentioned
must emphasise - not overclocking - just normal "stuff"
thanks
I've got it and its great stability wise and easy to Overclock with although if you ever did decide to overclock with this board be prepared to have a lot of paitence but considering your not overclocking then it all be alright, although if you only need a cheap c2d motherboard you could get something cheaper.
