- 23 Mar 2006
- Hampshire
Hi All
Has anyone had problems with SATA drive on this board before??
When I got the board I configured 2x 160Gb Sata drives as a mirrored pair.
I later decided that i didnt want this config and swapped back to raid disabled in the bios as I was having issues installing 64bit XP.
XP installed fine without the mirror running and both disks are seen with no probs.
I have now decided to go back to mirroring but Raid controller cant see the drives.
If I look in the Bios the drives are clearly present.
I then enable the raid mode and enable the sata drives for the raid.
The system reboots and instead of seeing an F10 prompt/Option the system just hangs saying its discovering the raid.
At this point it just sits there????
Am I supposed to leave it like this or what?
I have left it in this state for 15mins with no effect?
I donot get an F10 option.
I have upgraded the bios level to 2.0 to see if this helps but it makes no difference.
Anyone else had Sata Raid problems with this board??
