Abit Guru Tool
30 Apr 2004
Cloud 9
Hi guys
I've been messing with the Guru tool for the IP35-Pro and I was wondering what kind of settings are you guys playing with, and what performance (stable) you are reaching
My spec:
Abit IP35-Pro (latest Bios)
Q6600 G0
Tuniq Tower/Artic Silver
4 x 1GB Geil ULL @2.1v (4-4-4-12) Stock
Coolermaster case (1 x 120mm, 2 x 80mm Fans)
2 x optical 1 x HDD
8800GT
Vista64
Thank in advance
Monk
are you talking about uguru in windows or bios?. I managed 3.2 with my first OC last week (fsb 400 8x, mem to 1:1 800mhz) seems a pretty good clocking board, you might need to up the vcore after 3.1ghz as their is quite a bit of droop.
my experience with the u-guru windows tool is overall positive - always make sure you start out with the exact same settings on the tool as you have in bios, and avoid changing the pcie clock atall as this tends to give a instant hang. its normally possible to get to higher clocks using the tool for benchmarks than you could post from the bios.
