Hi All,
I am currently running Windows Vista, and decided that I would try installing XP as a dual boot option. (I was having various problems with a few Vista things that seemed to work fine on a friends XP machine).
Anyway, I got everything prepared and booted from my XP CD. When I get a scary error:
STOP: 0x0000007B (0xF78D2524,0xC0000034,0x00000000,0x00000000)
After doing a bit of googling, it seems it may be a hardware related problem. I recalled that I installed a new HDD and new RAM last summer and hadn't reset the CMOS (using the jumper switch). I can't find my manual for the MoBo nor does it want to let me download it from the Abit website! Could someone please help me in aquiring a copy and/or tell me how to reset the CMOS?
Also, on a slighty related note. I did think that perhaps the error was casused by the fact I had no SATA drivers installed/ready. But when I came to create a floppy disc with the drivers on I discovered that although my ancient floppy drive is detected it wasn't detecting the disc. Since I have 1xIDE drive and 2xSATA2 drives (one of which is where i want to install XP) im guessing that even if I get XP Setup to successfully run it wont see the 2xSATA drives, is that correct? If so, is my only option to use nLite to create a new XP disc with the SATA drivers included?
Sorry for the barage of questions but this is rather starting to annoy me now!
[EDIT] Also, I have read that this could be a RAID setting related issue but I can't find any RAID option in the BIOS settings! Any help/advice would be very helpful too.
Many thanks in advance for any help.
Alien
Alien
