right, 8E is due to it not detecting a cpu fan, how do i turn this off?
its gone back to 7E again, i get no display at all....tried a different gfx card, bios shows straight away on screen.........likely borked graphics card?
If it says it's not detecting a CPU fan, do you have one attached to the CPU fan header? If not, attach a fan there to get you into the bios, then disable monitoring of it.
