1 Feb 2008 at 21:25 #1 # 13 # 13 Associate Joined 20 Dec 2007 Posts 384 my MOBO has - 7.1 CH HD audio codec: realtec ALC888 i dont understand if this is any good its all kinda confusing will the sound on the MOBO be the same quality as a £30 sound card?
2 Feb 2008 at 20:23 #4 Monkeynut Monkeynut Soldato Joined 7 Nov 2007 Posts 6,827 Location Required Integrated will NEVER be better than a recent dedicated soundcard. Whether you can tell the difference though is a different kettle of fish.
2 Feb 2008 at 20:36 #5 NVIDIA_x64 NVIDIA_x64 Permabanned Joined 9 Oct 2006 Posts 1,161 Location Norwich If you have a £30 sound card and 5.1 there will be a big diffrence but if you only have 2 speakers then there would be little point.
2 Feb 2008 at 20:40 #6 # 13 # 13 Associate OP Joined 20 Dec 2007 Posts 384 well i got a surround sound system and astro a40 audio system
2 Feb 2008 at 21:44 #7 Hxc Hxc Soldato Joined 29 Oct 2004 Posts 12,501 Location London If you use some headphones you'll be able to tell the difference, you'll pick up a loaad of interference on onboard, usually. I'm buying a dedicated DAC/Headphone amp for my phones so I can get clean sound, it's worth it.
2 Feb 2008 at 22:04 #8 # 13 # 13 Associate OP Joined 20 Dec 2007 Posts 384 my headphones have an mix/amp www.astrogaming.com - my headphones
