they should both go to ~500 or so if you drop the multi & your CPU etc. are capable.cool tnx,
u see I was really worried about the oc cause i read in an article that the ip35-e wont go over 350 while the ip35 goes over 420
the IP35-E & IP35 are extremely similar mobos (as shown by the fact that they share the same BIOS) - basically the same design but the -E has only ICH9 versus ICH9R & firewire on the IP35.That article is always described by Abit supporters as very odd as the boards are supposedly the same, just with components missing. Now, that's patently not true as the IP35-E has 'wet' capacitors, the IP35 has a mixture of Solid and 'wet' and the Ip35-Pro has 100% solid capacitors.
Using the IP35-Pro to replace what? cause I see in your sign an AMD system
