Abit IP35 Pro - best memory ?
19 Oct 2002
Trick question eh !
i do NOT overclock but looking for the very fastest and safest combo
as in 100% fastest might be unwise - maybe 98% with a safety margin
but if normal is 70% i'm still way ahead
i think :confused:
anyway , something flash like ballistix or whatever you recon
full spec please as i find dealing with memory a pain
thanks
get yourself a 64-bit o/s if you want 8GB. I'd recommend Vista 64 rather than XP-64, the driver support is a lot better.
