Abit ip35 pro memory error
20 Dec 2007
I have Abit IP35 Pro with Intel E7650, OCZ 4GB (4x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
I'v tested my memory 1gb at a time with memtest and i have no errors.I put the 4gb in and i get hundreds of errors.What am i doing wrong:( does anyone have an abit ip35 pro with ocz 4gb of memory runing,could they help me with settings
Thanks
(cant find my last post :( )
Best place to find out would be here OCZ Forum Support the Ocz Tech's will reply to you within a few hours of posting, they are really helpful & know what their doing. :)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 said:
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- OCZ Lifetime Warranty
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
1) Put the DDR2 voltage to 2.0v
2) Increase the MCH Voltage in the bios by 0.1
If that doesnt work, increase the DDR2 voltage to 2.1v.
Also you may have to slacken the timings to CL 5-5-5-5-15. (CAS-TRCD-TRP-TRAS)
