Abit IP35 Pro
C2Q Q6600 Stock 2.40GHz
EVGA GeForce 8800 GTS "Crysis Edition" 512MB GDDR3
GeIL 2x1GB PC2-6400C4 800MHz Ultra Low Latency
Antec P182
WD Caviar SE16 250GB16MB x 2
Pioneer DVR-212DBK 18x DVD±RW SATA Dual Layer ReWriter
Thermalright Ultra-120 Extreme
Noctua NF-S12 1200RPM 120mm
Just built the computer
Finally installed windows after a couple of blue screen of deaths
ran Prime95 for an hour passed the test (about 5 total)
and a program OCCT it was stable (30 mins)
The problem is when I go to turn the computer on it wont work
Gets stuck at the abit logo screen
The only way to get into windowsXP is to clear the BIOS CMOS memory
then it works
but if I shutdown and power back on i get the same problem stalls at Abit logo (keyboard doesnt work)
any ideas?
BIOS is uptodate
Havent changed any settings in BIOS left to default
pretty much all drives installed windows, gpu
Antec P182
then it works
any ideas?
BIOS is uptodate
