Abit ip35 Pro review by xbitlabs
2 Dec 2006
Abit ip35 Pro reviews
http://www.xbitlabs.com/articles/mainboards/display/abit-ip35-pro.html
Hey. I just thought id post this incase it helps anyone out. Its almost sold me the motherboard. Im just reading some other reviews as well as ive read great ones on the Dq6 but i know that it doesn't fit cpu coolers well.
according to the review, the heat pipe layout is very good as it will allow you to easily install other cpu coolers and still gives good cooling.
Anyway, thought some of you might like to read it. Sorry if its been posted before. Ive got like 15 reviews up of differnt boards. I may compile them into one post for all you guys if they are any good.
lmao , the 2nd review.
NEW UPDATE: One of our readers has posted a solution for reaching higher FSB. " For OC you must disable EIST in the BIOS to get higher FSB." Although we haven't tried it ... any overclocking is done at your own risk. So DO be very careful.
8igdave, these great boards m8, would highly recomend them :)
