ABIT IP35 PRO XE memory upgrade question
12 Jun 2009
Hello, I want to upgrade my memory on my ABIT IP35 PRO XE from 4gig to 8 gig. I am unsure what would be compatible with my current PC2 6400 Gold serie (2gb x2 / OCZ2G8004GK), any help would be appreciated.
Thanks
This is as close as you'll get from OcUK:
OCZ Platinum Revision 2 XTC 2GB (2x1GB) PC2-6400C4 800MHz Dual Channel Kit £39.98
You'll have to run it at the same timimgs as your existing RAM (5-5-5-18).
Just note:
1. You'll need to have a 64bit operating system to make use of more than 4GB.
2. If your system is overclocked then filling all 4 RAM slots could affect the overclock.
3. For 95% of users there's no need for more than 4GB. For example you don't need more than 4GB for game playing.
Just realised this is only 2GB - see new post below
Thanks for the info guys. I am indeed going to install Windows 7 64bits and it is mainly for web design and web development.
