ABIT IP35PRO + Q9300 = 2 cores problem
23 Jul 2007
Newry
Hello just instelled q9300 bought from Overclockers. And windows shows 2 cores and using very high temp.
BIOS 16. Damage processor?
Update to the latest BIOS if you haven't already, then reset your CMOS and run a 'scan for hardware changes' in Device Manager. 51-56c is alright if you have SpeedStep off - your CPU fan is probably spinning dead slowly.
Couple of things to try if you have not so already, try doing a CMOS reset and do a search in windows for new hardware.
Temps, what heat sink are you using, try reseating the heat sink and what thermal paste and how much did you use.
Rob :)
OK
Coller Noctua NH-U12P CPU i chnged 3 times thermal paste no improvements. Orginal Noctua thermal paste. I celared cmos a couple of times no results. Device manager shows 4 cores. Bios shows 40C. Bios 16 ver.
Ok
After reinstalling Windows i have got 4 cores uhhhh.
But temperatures arent correct. I think thermal sensor is damage because i took off cooler and processor wasnt hot.
IDLE :
51
56
51
55
STRESS 100% (4 converter programs running ConvertXtoDVD)
64
64
64
64
