If you connect your case fans to the motherboard (I believe there are four fan headers), how controllable are they given BIOS or UGuru or speedfan settings?
Is it possible to have them turn off below certain CPU temps? To only come on at other temps? And to ramp up as the CPU gets hotter?
I'm obviously looking at this from the point of view while the system is doing nothing having fans running at a minimum, or even off, and then when the CPU heats up, the fans come on and/or speed up.
Anyone able to clarify exactly what can be achieved?
Thanks!
Thanks!
