Abit NF-M2SV Help
25 Nov 2007
London
recently made new pc bla bla bla...
using 5400 Corsair XMS2 ram 2X1GB , and i believe system might be unstable due to low ram voltage..
question is, how the hell to i increase voltage, ive gone to every setting in bios, and i just cant find it. does it even exist?, ive found where it tells me the voltage but you cant change it... its currently at 1.82 and i need to increase to 1.9 i think
thanks in advance
The NF-M2SV is the lowest version of that chipset in abit form (its a < £30 mobo).
It's designed just as a cheap desktop mobo, not any overclocking etc..As such it has very few BIOS options compared to e.g. the NF-M2 nView.
If it does have any RAM voltage options the most would be 1.9V as it's designed for use with JEDEC compliant RAM.
