Hi everybody,
I'm hoping somebody can help me with a problem I'm trying to track down with the above motherboard that involves data corruption when installing and/or transferring large files between from my Sata drive to IDE or vice versa?
I understand from a Google search that there are some 'issues' with the Nforce4 chipset and the data buses becoming saturated during large file transfers.
Has anybody got this board and solved the problem?
I'm going to try removing the Nvidia SW IDE driver file and replacing it with the stock Microsoft driver, which I've read might hlelp?
My spec is:-
Abit NI8 SLI GR Motherboard (upgraded to latest Bios)
PentiumD 805
1 GB (2 x 512mb) Corsair Value DDR2 (667 Mhz)
1 x 160GB Samsung Spinpoint SATA hard drive which is the Windows boot drive (set to Sata II mode)
1 x 40GB Western Digital IDE drive, set to slave mode on the Primary IDE channel.
2 x Optical DVD drives and IDE channel 2
1 x 7800GT Graphics Card
The system is not overclocked at all.
Windows otherwise runs ok.
I was going to try pegging the Sata drive back to Sata I mode, to see if the lower data transfer rate helped?
Any other ideas?
Thanks in advance!
My spec is:-
PentiumD 805
Any other ideas?
Thanks in advance!
