Abit Pro & Q6600 3.6Ghz Cpu Voltage Needed?
23 May 2007
Loughborough
Ok I currently have the above setup, what type of voltages are people needing to hit 3.6 Ghz?
Would be greatful if people could tell me there voltage in the bios to achieve clocks of 3.5 & 3.6 respectively.
Can it be as high as 1.5v to hit 3.6?
Thanks in advance,
Lea
Thanks for the reply matey, is that prime stable after say 8 hours?
With prime 95 how do I know whether the processor is failing or the ram?
Cheers,
Lea
