- 12 May 2005
- Cambridge, or somewhere else in the world
Hi,
I've the above mobo and I am having trouble booting up. I believe this is a the RAID/ACHP issue. I want my PC to be in a RAID1 configuration (mirrored) for data security. However, to get the option for that in the BIOS, I need to select either SATA or ACHP to be able to get into the SATA setup screen. However, if I use this option I find it very difficult - it will take a number of attempts - to boot. I get POST code 9.9. which I beleive indicates that the uguru chip has initiallised and is waiting for hte BIOS to take over. However it just hangs there, no beeps or anything. I tried a reinstall of vista last night and set SATA in the BIOS and set the discs to be a mirrored RAID and tried to install the RAID drivers at the appropriate point. - This resulted in BSOD.
Is it time for RMA?
Thanks!
Is it time for RMA?
Thanks!
