Able to use consoles on iMac?
6 Jan 2004
Halesowen
I have an Elgato USB tv tuner on my iMac, which uses coaxial connector, is it possible to use consoles with this? Would be great if it is.
If not, is there another way to do so?
Thanks!
<3
You'll need an RF adapter to convert the console's output to a format the coaxial input can understand but it should work for your purposes. Some consoles, particularly older ones, include this functionality by default.
Just, no :p
To do it properly, you'd end up spending more than the cost of a telly. Unless space is an issue, and money is no concern, I'd not even consider it.
