Hi, I recently built a PC and have seen some abnormally high temps that have stumped me a bit. Latest AMD chips do operate at high temps but these are hitting 95
Some key specs are:
- Ryzen 9 9950X with no OCs
- Zotac Solid RTX 5090
- NH D15 G2 (Mistakenly ordered HBC, but it's mounted with the 7mm offset)
- Fractal North case
Temps seem to sit on the upper-end of normal at idle within 50-60C, going up to 70 with fairly trivial load. The temps rise quickly under synthetic and regular loads (Prime95, Cinebench, Minecraft chunk gen), constantly sitting around ~92C and sometimes hitting the max 95C temp within 10 minutes. I thought it was the NA-TPG1 paste guard being knocked off-center at first, but two attempts at re-pasting, completely removing the guard, and checking the cooler's screwed in securely have largely come out the same. I've got some extra case fans for exhaust on the way, but it still seems like the D15 is being hit too hard. Does anyone have any good suggestions on what to test next before an exchange with OCUK? Thanks for reading
