About that HPET setting...
zer
zer
6 Jan 2004
Greece
Hi there!
I am totally confused about all this noise concerning Spectre,Meltdown patches and lately, HPET at default or forced on setting...English not being my mother toungue doesnt help either...
So, guys: What is the punchline here?
Someone with Intel CPU (i have i5 8400) and Win 10 should check some settings, besides having the latest win 10 updates installed (which is all i do)? PC used mainly for gaming, but web browsing, power point creation etc as well ...
Many thanks!
So it only makes about a 3% difference.
Games seem to be different.
Thats still only 3% with Tomb Raider only 7%, can you show me 5 games where the same is true or is that just a one off?
Just quick testing, Far Cry 5 is defo a change I have benched that so much lately so I know any change in that is correct.
Am not here looking to jump to the hills on performance :D a gain is a gain end of the day. Am more interested in seeing how games play. People are reporting smooth performance from better CPU load to the GPU. Squad will be a nice test for this but sadly no in game benchmark for that.
The problem is some people like to proport that its 30% +, its nothing like that is it?
Some of the big hitters from that link above I sadly dont have installed. I do have GTA 5 though i can test.
Anand's revised HPET runs they claim they get 76% higher performance for RoTR on the 8700K.
I just have a hard time reconciling this, i ran RoRT on my overclocked GTX 1070 and got around 100 FPS, this with the GPU mostly maxed out.
That's about the same as Anand reported on their initial run with the GTX 1080, now after getting complaints that Ryzen 2 didn't look far enough behind Coffeelake they say the problem was HPET and they are getting 76% higher performance with it off, i know the GTX 1080 is already maxed out at around their original result, because i have a similar GPU and the game, its not possible to get 76% more performance out of it, 10% at best.
Now if they had said 10%, fine.... but they have gone to ridiculous extremes. its clearly nonsense.
Everyone is really overthinking this. Windows 10 does not use HPET unless you tell it to. If you haven't done that, it'll be off and you're fine. Just run the command to check in Start -> cmd:
bcdedit /deletevalue useplatformclock
If it errors, HPET is already disabled.
I did this and got error, but this doesn't explain why I seeing gains? I disabled HPET in device manager.
You are messing with timers and expecting accurate results from benchmarking software that relies on timers?
This, and its actually turned on on Ryzen CPU's because those times were causing them to report much higher clocks than they actually were.
It also explains Anad's clearly wrong revised performance figures.
No if HPET is disabled on Windows 10 by default then I should see zero change in my results. Thats what i dont understand. Is it possible that Windows 10 applications can use HPET on the fly while the OS doesn't?
That's exactly the point. Applications that want to use HEPT can do so, but you are forcing it disabled so they can't. If they are expecting to be able to use HPET but can't, then you can't trust the benchmark results they give.
