Its a shame OC don't sell then![]()
why ??? Why buy old tech when the 6970 or 6990 is soon out :O
The gap depends on the motherboard you are using
They do. look in clearance. There is more watercooled stuff in there than in the main section
Hope this help's.Is your Sig up to date then?Yes
Is the motherboard in your sig the one you are going to add the second card to? Yes
Do you only have the one rig No & is this shown in the Sig?No
and will no doubt perform around 10% better than a 480
or exactly the same if you clock it...
he has 3d vision, so the requirement for sli is justifiable.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-PB&groupid=595&catid=667&subcat=1747
http://www.overclockers.co.uk/showproduct.php?prodid=WC-007-PB&groupid=595&catid=667&subcat=1747
Feser also make a 1/2/3 Slot Pack that will do all three positions.
OcUK do not sell these unfortunately but google is your friend
Let me know how 3dvision surround goeswhat 120htz monitors you got?
Nice! I've got the 2233 Samsung, I can imagine Trine in 3d surround being pretty awesome. If you haven't tried it already should try (physics based puzzle). Got any recommendations?
