about to click buy
16 Nov 2008
final checks.....is this system worth the money....and is all compatible etc !!!! FIRST PC BUILD
P43 boards don't clock as well as P45 boards, so I'd be reluctant to get that motherboard. With the 5200, high fsb isn't really an issue so it's not going to matter as much.
Worth finding a review of the motherboard and checking it comes with at least two sata cables, as oem drives wont
Not sure how to reword "Worth finding a review of the motherboard and checking it comes with at least two sata cables, as oem drives wont ", so someone else may have to take a stab at that.
If you're not overclocking then that board will definitely be fine.
I'm unsure how much of it will be assembled, I'd expect it all in boxes but it's possible they put things in the case for you.
